Ga door naar hoofdinhoud
The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
How to fix stick drift?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This probably won't help, but it's worth a try. And that's cleaning them, preferably with 90%+ isopropyl alcohol.
If that doesn't help, you will probably need to replace the whole joy-con, I don't really know how it looks in the Quest Controller but I'm 99.9% sure that it's using the same design as everyone else. So you may need to figure out how to get it apart yourself.
The problem is in the design where after some time the surface in the joy-con that the signal goes through is worn off and loses contact.
Hope this helped! :D
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the help.
door
@nytryder26 No problem! :D
door
Voeg je antwoord toe
NR26 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 446
