Samsung Galaxy A51 stuck on charging icon (lightning bolt)
I have a Samsung Galaxy A51 which is stuck on the charging icon (lightning bolt). It shows no battery percentage. I tried replacing the battery and charging port but the problem remains the same. There is no liquid damage inside the device. Is there something I haven't thought off? Or is it a main board issue? I also tried force restarting the device with the volume - and power button
Is dit een goede vraag?
If you have the 4g version have you tried replacing the flex cable from the charging port to the mainboard?
door Daniel
Thanks for your reply, forgot to mention it but I already tried it with a new main flex cable. Also tried getting in recovery or download mode but that also doesn't work.
door Koen Tuithof
I also have the A51 and the lightening bolt is there when the phone is showing 100% charged. It works all day on usually just one charge which I doi overnight with the phone turned off. I just switched out my charging cable to try to stay a step ahead but even with the old cable the phone was still charging to 100%.
door Martha Gammino
I have the same problem my Samsung galaxy A51 stuck at 67% percent never progressive what should I do?
door GMAR UP
I put my Samsung a 51 on the charge when I wake up tomorrow, the phone was power, off when I press the start button, the phone can’t that time I don’t know what the problem I think the phone is died
door Farooq Ragwal
2 commentaren meer tonen
