Ga door naar hoofdinhoud
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
118 Vragen Bekijk alle
Where do I find firmware for my TV?
I just purchased a Mitsubishi WD-82738 82" DLP 3D TV and seems has never been updated once. I need a firmware update of 12.7 or higher to enable 3d enhancement features and 1.4a hdmi protocols so I can use it with modern 3d players like ps3 or 3d blu-ray players but Mitsubishi discontinued their sales and firmware downloads and I can't find it anywhere.. Help!
Is dit een goede vraag?
Score 2
3 opmerkingen
https://www.mitsubishi-tv.com/contact-us...
Try contacting Mitsubishi's customer support. If that TV has an available update, it's possible that they will provide it.
door
Thanks Funk gave it a shot but they have no idea how to help. They have not had access to any firmware or support to their TV's for a decade, even the 4 TV Mitsubishi certified repair shop numbers they gave me were all disconnected.
door
Finding the firmware for your TV can be a useful task if you are experiencing issues with your TV's performance or if you want to update it with the latest features and fixes. Firmware is essentially the software that is embedded in your TV's hardware, and updating it can improve your TV's overall performance and stability.
It's important to ensure that you download the correct firmware for your TV model and that you follow the instructions provided by the manufacturer carefully. Failure to do so can potentially damage your TV and void your warranty.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You can try to find what you need by searching in the internet archive wayback machine, if you're lucky the download you need will be archived here's a link to get you in the ballpark: https://web.archive.org/web/2011*/www.mi...
Adrian ok, I won't be lazy.. . But all you needed to do was search the archive until you found this link
https://web.archive.org/web/201012212238...
Instructions. Are here
http://www.mitsubishi-tv.com/3Dupgrade_i...
New operating instructions are here
https://web.archive.org/web/201105211435...
I WAS too lazy to keep searching for a later upgrade, if any...
Anyone else with the same problem but different model
(WD-60738, WD-65738, WD-73738, WD-82738, WD-65838, WD-73838, WD-82838 only)
go here instead
http://www.mitsubishi-tv.com/3Dupgrade.h...
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Juan, you are the Man! I was giving up hope and was going to spend $200 on a 3D converter kit. Now, a seemingly common issue as I see through old forms, why the TV won't read the USB drive lol
door
@Adrian Freelancer Awesome! You should link it here if possible. Thanks!
door
If it can't read your thumbdrive try an older, slower, smaller cheaper one, a geriatric tv needs a geriatric usb stick. Look in the manual to see what it can read.
door
Before you ask your manual is here
https://www.manualslib.com/products/Mits...
If you are feeling grateful send part of that $200 you saved to the internet archive or right to repair both of which were instrumentals in your salivation LOL.
door
I hate spell checkers!
door
Voeg je antwoord toe
Adrian Freelancer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 56
Altijd: 992
