Ga door naar hoofdinhoud
2.16GHz Intel Celeron N2840 Processor with Turbo Boost Technology up to 2.58GHz On-board 2GB 1333MHz DDR3L SDRAM & 2GB eMMC 11.6" HD AntiGlare WLED-backlit display (1366x768)
My HP Stream Notebook PC 11 keyboard is malfunctioning
  • Most times when I strike a key different programs open
  • Another problem is when I type on ms word a certain key will just be reporting itself
Is dit een goede vraag?
Score 1
5 opmerkingen:
What is your exact model as each series is designed differently.
door
Hp Stream notebook PC 11
door
Hi @laminkanu
Try plugging in a USB keyboard and check if that works OK.
This is to prove whether the problem is in the laptop keyboard or in the OS.
Has the laptop gotten wet at all i.e. liquid spill on the keyboard?
door
I have also tried an external USB keyboard. But the Sam problem repeatedly happens.
Secondly I didn't spill liquid on the keyboard.
door
@laminkanu
Seems as though the problem is in the OS and not the keyboard.
What OS is installed, Win 7, 8.1, 10?
Is it always the same programs that open?
Have you checked that the programs can't be opened by keyboard shortcuts?
Either on the desktop (if the programs have icons there) or in the list of programs, right click on the program icon of a program that opens and click on Properties > select Shortcut tab and check that the "shortcut key" entry = none.
door
Voeg een opmerking toe
1 Antwoord
Como estas Amigo,
Asi como describís el problema puede que ser virus, algún keylogger , te recomendaría antes que nada correr un antivirus en modo a prueba de fallos, para descartar esa posibilidad.
Was dit antwoord nuttig?
Voeg je antwoord toe
Lamin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 303
