Ga door naar hoofdinhoud
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 Vragen Bekijk alle
laptop dropped headphone port blocked
hey y’all! i bought this on Ebay recently and while the listing did mention the dent/drop, it also claimed full functionality… as it stands now, the headphone jack is unusable bc headphone cables won’t fit into the port
The seller does offer returns but I’d rather just try and fix it if possible, would it be worth it try and bend the metal back out of the way of the port? maybe some very shallow drilling at the tip of the port?
Is dit een goede vraag?
Score 1
2 opmerkingen
Is the jack not fitting because of the damage to the case, or does the jack not fit due to something inside the port?
door
it’s the case, i was able to get a similarly sized allen key down the port leading me to believe there is no blockage. @jmehnert
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Given what I have been told, your best bet would be to drill with a similarly sized drill bit. Go really slow and only drill enough to get the metal out of the way of the port.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
that worked!
door
Ouch! The case is quite damaged (bottom cover too) as well as the lid frame as well. If you got the system for real cheap then it might be fixable but not like new nice and pristine!
You may need a new MacBook 12" Retina (Early 2015-2017) Audio Board and before you do any metal work make sure you've disassembled as much as you can and protect the electronics for the metal filings.
MacBook 12" Retina (Early 2015-2017) Audio Board Afbeelding
Product
$39.99
Score 1
1 Opmerking:
that's probably the smarter advice, but I actually just took a drill to it as is, only took a few very slow rotations and boom problem solved!! and i didn't get it for super cheap but im not stressed about it, bought it as an email machine for work ... dont need it to look pretty. :)
door
Voeg je antwoord toe
rick davis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 140
