Ga door naar hoofdinhoud
Model A1046 or A1095 / 1280x854 screen resolution
118 Vragen Bekijk alle
Wire from airport antenna broke off from connector
I'm replacing the screen on a G4 powerbook. While disassembling the unit to remove the display I inadvertantly broke the airport antenna cable right at the connector when I tried to disconnect it, consequently the connector is now rendered useless.
My question/s is/are: Can I use a small butt connector to reconnect the airport antenna cable to the airport card cable or do I need to use the exact same type of brass connector?
If I do indeed have to use the same connector, where might I find one?
An answer to one and/or both of these questions would be most appreciated.
TIA....Jeff
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hello Jeff, The way I would go is to buy a replacement cable for a complete and trouble free repair. Link provided. Good luck.
[gekoppeld product ontbreekt of is uitgeschakeld: IF154-044]
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks rj....Yeah I was looking at this earlier and actually added to my cart but I wasn't sure whether or not the antenna cable had the connector attached to it as the picture is somewhat indistinguishable. So I guess I'll just go ahead and order it....Cheers
door
Voeg je antwoord toe
Jeff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 825
