Ga door naar hoofdinhoud
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
A.C Not working in front of the vehicle
Just getting hot air. Even after i move the switch to the A.C Possition is still blowing hot air
Is dit een goede vraag?
Score 1
1 Opmerking
You might be better served finding and joining Ford Explorer forums where similar owners share answers.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
There are a few basic points that you have to check if getting hot air from AC.
  1. Check the AC mode. Change it to the cooling mode.
  2. Clean dust and slit from the fin of the AC. Use water and soap foam to clean it.
  3. Check the temperature sensor.
  4. Confirm you have cooling gas in your AC and the compressor is working.
Was dit antwoord nuttig?
Score 3
I paid $500 to replace the compressor, only to find out it was just a loose connector on the condenser fan…
Voeg je antwoord toe
Edilberto Sibrian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 446
