Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
Where to place optical fan sensor on an SSD/Optibay adapter.
My optical fan rpm's are going over 2500 since I installed an SSD in the dvd superdrive slot. I got the adapter from ifixit, but not sure where to put the sensor. Right now, i've got it in roughly the same area it was with the dvd drive, but I think it's running way too hot/fast. Any ideas to get that fan to calm down??
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here's an installation of a SSD in a iMac. Note the placement of the temperature sensors.
http://www.thatsiebguy.com/2009/10/iMac-...
If this does not fix the problems then we need to look at fans control resets
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
An SSD drive should run much cooler than a standard drive as there are no moving parts.
door
Here's where to download a fan conrtol for the iMac: http://www.macupdate.com/info.php/id/230...
door
That installation is using an SSD to replace the main HDD. My installation replaces the DVD superdrive. Any knowledge where the coolest place on that side of the iMac is to place the sensor?
door
Voeg je antwoord toe
hellohogo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 3,443
