Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Handleidingen en reparatie-informatie voor KitchenAid mixers.
Mixer won't turn on. Sometimes if I give it a tap it will turn on
Sometimes its a toss of a coin if it turns on when I plug it in. Sometimes if I give a tap it will turn on.
Is dit een goede vraag?
Score 2
1 Opmerking:
We have the problem too any answers what needs to be fixed?
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Did you review questions reated to KitchenAid Mixers? If your question is unanswered then you'll have to examine wiring from plug to main power switch with a multimeter checking for continuity on both wires to the switch.
Was dit antwoord nuttig?
1 Opmerking:
Can't find any fault in the posted answer, and would have inferred from the description, that you're dealing with a 1) loose connection or 2) a broken wire, and that the physical motion of 'tapping' causes the connection/wire to complete the power circuit - and the motor is energized. A continuity check of the power cord connection/contacts, would be the first place I would check/test.
door Deel
Voeg je antwoord toe
Esteban Martinez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 446
