Ga door naar hoofdinhoud
Socket 1366 is ontworpen voor vroege Core- en Xeon-processoren.
Does resettable fuse has direction?
Hi, Does resettable fuse has direction of installation ? Thanks
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No, resettable fuses do not have a polarity.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
Thank you 🙏 🌞
door
no
”Comparing PTC fuses to one-time fuses Every fuse has an amperage rating and protects downstream circuit components from damaging overcurrents. Both one-time and PTC resettable fuses connect in series with the load and are not polarity sensitive. PTC fuses reset themselves, whereas one-time fuses open the circuit as a one-time positive disconnect and must be replaced before resuming operation. Both technologies require the removal of the overcurrent condition to resume normal operation. Due to this key characteristic, selection parameters differ — some of which are compared in Table 1.”
https://www.eaton.com/content/dam/eaton/...
Score 2
1 Opmerking:
Thank you sir!
door
Voeg je antwoord toe
Formingus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 1,006
