Ga door naar hoofdinhoud
A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
114 Vragen Bekijk alle
CTO iMac 27 5k 2019 with 2TB Apple SSD. Does this include a SATA cable
It would be an iMac 27 5k 2019 purchased in a CTO configuration. It comes pre-ordered with a 2TB Blade SSD from Apple and therefore does not include an HDD (Fusion drive).
My question would be if I buy a SATA SSD installation kit. will my HDD Data and Power Cable be included in my iMac? If not, what cable can I replace?
( There would be a cable detailed on page 88 of the Repair Guide PDF. ***``Service Manual - iMac 5K 27-in (2019).pdf )
The end result would be to have one Blade SSD and one SATA SSD in my iMac.
Thanks for everyone's help.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Apple does not install the SATA / Power cable 923-00664 when you get a blade SSD model you’ll need to buy it if you are adding a SATA drive (HDD or SSD).
Here’s the location of the connections, the Orange marked is the data and the Red marked is the power
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thanks for the quick reply Danj.
Then the brain was confirmed.
Where can I find this SATA / Power cable 923-00664 cable here on iFixit?
door
Sorry, iFixit doesn't offer this cable here's one source iMac 27" Retina 5K Hard Drive Combo Cable (L15/17/19), Apple P/N 923-00664
door
Thanks for the help. That's how I'm going to proceed. :)
door
@amp_hw_rep - Don't forget to accept the answer - Thanks!
door
Voeg je antwoord toe
Peter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 278
