Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Krachtige tablet van de 2e generatie, uitgebracht door Apple in juni 2017. Model A1670.
Is it possible to use a 2015 (1st Gen) screen on at 2017 model?
I have a 2015 1st gen screen and an absolutely smashed 2nd gen screen I took out. I did not notice until I started that the home buttons cable was way to short on the replacement screen which was a 1st gen. I was wondering if its possible to just put on a 2015 home button and reconnect it to the body of the iPad
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
have you removed the broke screen yet? if so lay them side by side and see if the ribbon cables match up. if so there is a possibility. but knowing how apple hardware locks stuff id venture to say probably not.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I have removed it. The ribbon cables do match up but I am worried about the touch ID. Right now it looks like getting a new one is more worth it than getting a 400$ 2nd gen screen.
door Deel
@ashleyfixz if thats the case id make sure you can return it if it wont work. again with apple its hit or miss on other hardware working at all to be honest. there has been alot of problems with trying to use the same stuff for their electronics and having it not work.
door Deel
Voeg je antwoord toe
Ashleyy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 51
Altijd: 435
