Ga door naar hoofdinhoud
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
120 Vragen Bekijk alle
boot loop apple watch series 0 sport. on both charger & off
I have a issue on a series 0 sport which is basically a series 1. I did a battery replacement from a totally dead battery. The new one gets past the snake charge screen so the battery got initialized but now it boot loops. logo 3 seconds power off. repeat every 5 min or so. force reset doesn't fix it. do you think battery isn't good? not enough voltage? no damage to the gasket touch sensor that I can see. left it on charger for 3 days so far to no help. I unplugged the battery for a day to ensure it had no power and it didn’t help. I get the boot loop on and off the charger so the battery has some power at least. It never charged more than 2.2w according to my kill a watt meter and it did this in a weird way. 7 seconds charge 5 seconds no charge. it now shows 1.3w now with same same cycling. could this new battery be bad? never seen this before.
Update (03/20/2022)
Here is what it does one charger or off the charger. Reset doesn't help but does attempt to reboot fast than the 5min cycle
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You really want to have a look at those two other questions with the same issue:
Apple watch stuck in a boot loop
Apple watch original boot looping on the charger
Both point to the battery as being the likely issue. The latter link points to the battery replacement guide.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
stressmaster zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 91
