My truck will not start the anti-theft light will not come on
My 1998 ford expedition will not start and now my anti- theft lite dus not come on
I tried to put a code reader on it to see if there was any codes and the data plug dus not work I check all fuses on it and they are good soo can someone please help me
Is dit een goede vraag?
You might do better asking in Ford Expedition forums. Auto forums may be the best place to share problems and answers.
door F Dryer
I have the same issue, my PATS is currently unplugged but the theft light does not Flash and the vehicle will not start. The theft light will flash briefly every couple seconds when the key is out of the ignition like normal so I know the bulb is good. The fuel pump will prime for maybe half a second and none or my guages are working at all. I've checked all relays and fuses, even combed through the wiring to look for burned or chewed wires but found nothing. The truck was running fine, I parked it for about a month and she just wouldn't start back up.
door Griffin
Fjoe Burton hasn't replied. Perhaps his problem was fixed and like many, neglected to post results.
Without knowing what you're driving, no assumptions can be made to suggest steps for troubleshooting. Some EFI systems like GMs cycle fuel pumps at ignition On time to pressurize the fuel rail just before starting up to lower cranking time. As most know, EFI systems allows instant starting in any temperature without any gas pedal input.
door F Dryer
