Ga door naar hoofdinhoud
Released November 2018 as an edition to the iPad's Pro line. Model A1980.
iPad unavailable, I’m locked out
I just want to restart my iPad by erasing it. It’s currently on airplane mode so I can’t restart it remotely. I can not erase it from iTunes either because the computer isn’t recognizing the iPad. I’ve also tried the power + volume shut down that does not work either. The port will charge the iPad though. What gives and help please.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
I had a similar issue with a iPod touch 6
This video shows you step by step how to basically force the iPad to restart and erase
https://youtu.be/9CHHCDexyHE
Hopefully this will help
Any questions please ask
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
Well I tried taking to Apple because I do not have computer they said it has a bad port but it still charges with no problem. I did try the restore but that did not work either. My iPad Pro 11 is a Wi-Fi edition and it’s stuck on airplane mode. I did not put it on that but when you fly it automatically goes to that.
door
Having the same exact issue. Do you think it’s the USBC port that needs to be replaced?
door
@lg2
Hi
Sorry about the very delayed reply,I didn’t get a notification saying you had commented
It could be worth taking it to a repair shop the specialises in board repair to see if it’s a board level issue in any was because like you said if it charges fine the chances of it being a bad port are quite low
door
@chisss
Like I said in the comments above it could be a port issue but if it charges that is unlikely
Your best buy is to take it to a specialist repair shop to see what they can do with it:-)
door
Voeg je antwoord toe
lg2 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 76
Altijd: 3,386
