Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
Replacement battery not charged?
Hello!
Im doing a battery replacement for my iPhone and the replacement seems to be depleted? I made sure this was true by testing my old battery and new battery (to make sure I didn't mess anything up) then putting the new battery on a charger. It first gave the normal empty battery charging symbol iphones usually do and came back up after some time on the charger. Is this healthy for the replacement battery to be fully depleted upon receiving it? Should I send it back to IFixIt?
Thanks!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Nothing to be too concerned about, as long as it's charging/discharging normally.
Some batteries arrive empty like yours, some arrive with 90% charge.
You will however lose the battery health section unless you replace the BMS board, OR use a tag on flex and programme via relevant programmer for the relevant manufacturers flex.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Tyler Luce zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 432
