Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
103 Vragen Bekijk alle
Is it possible to upgrade the CPU?
Hi!
I’d like to know whether it’s possible to upgrade the CPU on the 20 inch model From the 2.6 GHz version to the 3.0GHz version.
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
While is can be done, it doesn’t offer enough benefit given the amount of work needed and finding the proper CPU chip for your system.
Why do you think this is the best direction for you?
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Thanks for your quick answer!
I thought of doing this because it only costs about 70€ and I wouldn’t mind the effort if it would actually work.
The problem is that I’ve been looking on other threads about very similar questions and they say that it sadly is not possible, but I haven’t found the reason why they believe so.
Do you know what the criteria would be for a CPU replacement?
door
@whatcanifix - You require this CPU: 3.06 GHz Core 2 Duo (E8435) to replace your 2.66 GHz Core 2 Duo (E8135) CPU. Finding one of these CPU's is very difficult and it could be expensive.
Given all of the other limitations of this system its a lot of work with very little improvement. Your system is part of this series iMac9,1
Take the time to review your's 20" iMac 2.66 GHz Core 2 Duo (Early 2009)
door
So it is not possible to use the Intel Core 2 Duo T9900 (Socket P)? It seems to be the exact same processor with the same specifications. They are easier to get
door
@whatcanifix - Square peg won't fit round hole ;-}
You must use the E8435 processor no other will work.
door
Ok, thanks a lot for your answers!
door
Voeg je antwoord toe
Max zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 117
