Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
How To Program iPhone 3G LCD/ LCD Datasheet
This question also appears on the "Discuss" board.
I like working with microcontrollers such as those in the Arduino platform. Now that I've replaced the entire display assembly of an iPhone 3G with a IF137-008-1, I'm left with a perfectly good LCD unit that the customer won't want. Is there a datasheet for the LCD and perhaps even a development type PCB that I can plug it into and play with?
For example can I set this up so an Arduino Mega can send a jpg photo to the LCD with some nice caption text?
Thanks
Bob
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
from some teardown reports I have read, I heard that there are maybe 3 likely manufacturers of the LCD module:
- Toshiba Mobile Display
- Sharp
- Samsung
However I'm not sure if it's easy to find the datasheets for the specific panel, but you may be able to do some digging knowing the makers. I don't know if the manufacturer's part number appears on the panel.
on the other hand, I also read that the iPhone 3G uses a National Semiconductor chip to interface to the LCD display, the LM2512AA Mobile Pixel Link display interface
http://www.national.com/pf/LM/LM2512A.ht...
perhaps you can get a clue from it's data sheet and go from there.
have fun and good luck
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
cochranb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 12,937
