Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
20 Vragen Bekijk alle
Replaced Hard Drive with Compact Flash, Unable to Restore
I’ve wanted to upgrade and restore my Classic iPod 4th Generation for sentimental reasons. I’ve replaced the battery and the motherboard, the final goal was to replace the old 60GB mechanical drive with something less fragile and more power efficient. I’m stuck though, because the Compact Flash card (no matter how I prepare it), can’t be written to once installed in the iPod. I format the Compact Flash card on a Mac as MacOS Extended Journaled, it shows in finder as 64 GB. But if I insert that disk in the iPod and mount the iPod to the same Mac in Disk Mode, it shows as 187.6 GB, with an unformatted partition scheme. If I try and erase the disk in Disk Mode, Finder gives me a generic input/output error.
When I try the same exercise with an ancient 128MB Compact Flash card, it is recognized just fine, but too small to do anything with.
Is there something about this modern day Compact Flash card that is giving me trouble? Stumped.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi
Sorry to tell you but some flash adapters are just like that
There is this guy on YouTube called dankpods who does this sort of things and he will tell you the same thing
There is a company called iflash that makes the adapters and the are really good when it comes to restores and things like that
But one more thing before you buy anything what I would try is download the software called superduper
Put take all data from the old iPods hdd and copy it straight to the compact flash adapter
And cross you fingers and hope that it works
If you have any more questions please ask
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Phil Niemeyer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 776
