How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
Is dit een goede vraag?
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
Was dit antwoord nuttig?
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 216
6 opmerkingen
Do you have a hot air station?
door Andrew S
nope
i guess i'll just replace the motherboard
door notnice -96
i'll need to back it all up
door notnice -96
@andrewsawesome what if i did?
door notnice -96
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
door Andrew S
1 commentaar meer tonen
