Ga door naar hoofdinhoud
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
27 Vragen Bekijk alle
Why am I not getting power to my fuel pump? I have replaced the batter
Not getting power to fuel pump 2005 Ford explorer xlt.
Battery,Fuses,fuse box relay, Emergency shut off fuse,fuel pump drivers module,fuse for fuel pump,fuel filter, fuel pump and crank sensor all have been replaced and still I am have no power to the fuel pump at all.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Hi, I found this when I was browsing around a bit for some info.
I would start by checking the fuse in the fuse panel under the dash, and look for if the fuse F9 is intact (2A)
Then I’d check the fuel pump relay in the Battery Junction Box, if that operates as intended.
Hope this helps.
If you have more info to provide, you can always update your question with more info.
*Edit, removed broken link
Your car seem to have an electronic shutoff switch in case of a collision, have you checked that it’s not active? Ford explorer 2006 Owners Manual pg244
Was dit antwoord nuttig?
Did u try give power to fuel pump with prob tester ? To me this is some grand issues or PCM u have to check wiring from fuel pump to PCM
Voeg je antwoord toe
Laura Ock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 784
