Ga door naar hoofdinhoud
How to troubleshoot a gray screen on start up.
I have a Apple A1010 laptop that when you turn it on, it chimes and goes to grey screen and doesn't do anything. It is not the hard drive or the memory because I tested them in another laptop.
Is dit een goede vraag?
Score 2
3 opmerkingen
I did that but the ram is good this laptop has 128MB of built in RAM thats not removable. could that be the problem
door
When you tested your hard drive in another computer, were you able to boot off of it? If so, you might want to make sure everything is connected properly inside you laptop.
door
yes it booted up fine and the conections are tight.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I guess you tried all usual troubleshooting stuff like reset the pram, reset the PMU, boot from external source, boot in single user mode, fsck scan, connect the PB to an external monitor, etc ?
Was dit antwoord nuttig?
Score 2
Test the RAM in another laptop, could just be bad RAM.
Voeg je antwoord toe
Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 2,524
