Ga door naar hoofdinhoud
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
27 Vragen Bekijk alle
Why isn't my ac cigarette lighter outlet not working.
my cigarette lighter isn’t working, I checked the fuse box but the fuse was still good.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@srw23 the only thing between the cigarette lighter and the power is the fuse. Since the fuse is still good, check the wiring to the outlet and check the see if the outlet receives power. Use a test light or a meter and trace the wiring. You did not tell us which year your Explorer is but check fuse #24 in the instrument panel fuse box and fuse #7 and #9 in the fuse box in your engine compartment.
Was dit antwoord nuttig?
Voeg je antwoord toe
Southern Williamson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 271
