Ga door naar hoofdinhoud
This guide page will help you diagnose problems with the Toshiba Satellite C55-B5200.
9 Vragen Bekijk alle
I've lost the screws for my battery for me Toshiba Satellite C55-B5290
I have a C55-B5290. My CPU fan bit the dust (I know how to fix that that’s to this site!) so I removed the battery. I thought I had saved and put the screws in a safe place. Well, it was so safe that I can’t find them! This site is telling me that the screws are 9mm #1 Phillips screws. Where do I find these screws??!! I don’t think that they are the same screws that attach the back of the case to the laptop. I don’t need the internal screws that someone would use for a tower. I wouldn’t be going to a hardware store like Lowes for these, would I? I wouldn’t think so.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Deanna M since it is a Toshiba the screws will be metric. Yes, Lowe’s has metric screws but probably not the diameter ;-). The way screws are measure on here is by length instead of measuring the actual screw size diameter. This has been my complaint for years. Anyhow, since it is a Toshiba there are not a lot of screw guides out for it. I would suggest you get a whole replacement set for your laptop. Something like this should work.
Was dit antwoord nuttig?
In terms of finding screws, you can usually find a close enough match with a generic laptop screw set with most consumer grade laptops like yours. Most of them are made by Clevo or Sager, so you can often get a generic screw kit and find a matched screw that’s a little shorter but fits, or a match with many of these. That said, it may be a little trickier with Toshiba/Dynabooks as they’re notoriously hard to pull service information like this out of - they have their lawyers work overtime to hide the information we need.
That isn’t as true with the business class equipment, but usually if you buy it from a manufacturer like HP who supports repair, it’s a non-issue but say if my 840 G5 needed a screw I often need to buy a screw set from HP as the business lines are different enough you often can’t buy a generic set online.
Voeg je antwoord toe
Deanna M zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 256
