System hangs on boot, if it boots it hangs soon. What to check?
Has been running reliably since @dan helped me last year with thermal paste issues. Suddenly the system will hang partially through a status bar or if it goes to user menu, it will let you log in but it will either hang within a few minutes or begin a restart cycle.
Tried to go into safe mode and it hangs there also. Tried recovery mode, started disk utility to check ssd and on pass 3 of 7, it froze!
A few times, a crackling quick pop was heard briefly…what should I focus on power supply? logic board? Thanks!
Is dit een goede vraag?
3 opmerkingen
@mbed - Did you not see my post in your earlier Q?
door Dan
yes but wondered if it could be other components or is it most likely the logic board? i know it is possible to be psu but is it likely? was pondering buying a pull logic board with faster cpu and also a pull power supply.
other option is to buy a more recent machine but overthinking before deciding? the 21.5" 2019 4k seems to be most upgradeable or the 2017?
would swap the ssd in the 2013 to the newer one if i go that route....would it just boot or are there boot parameters that need to be modified?
door mbed
the upgrade of the 2013 would be a dead end for it...least expensive solution though. wondering if I just tried the psu? is that worth trying or is it extremely like to be the logic board?
thanks!
door mbed
