Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de vlaggenschip Android-smartphone van Samsung, de S20 Ultra, uitgebracht in maart 2020.
S20 ultra won't charge past
I’ve tried a new charge port, ribbon connectors, wireless coil, and a new battery. Its says that the battery a 0% until I plug it in where it shows a charging symbol. From there I have to press volume down and power to turn it on. Then once its on, it won’t charge past 50%. I wish I knew what is all of the components is connected to charging so I could brainstorm on the issue.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
If it used to be a demo or something check to see is retail is still on, if so try to disable it, then it should work fine, if it was not if it has most of it's storage taken up by ‘system’ then factory reset it, otherwise you might have to put in a new battery or try powering it off and charging it.
Was dit antwoord nuttig?
3 opmerkingen:
Lemme know if it any of these work by commenting
door
I’ve already put a new battery in it and factory reset it.
door
Have you been able to resolve it and how did you do it?
I'm having similar problems. I press volume down and power and then plug it to power it on and it stays at 50% and doesn't charge and drains off when I keep using it. I have changed battery and changed new charging port/panel the same thing happens. It doesn't charge and stays stuck at 50%. What do I do?
door
Voeg je antwoord toe
Terence Mallett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 535
