Ga door naar hoofdinhoud
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
78 Vragen Bekijk alle
My İMac wont work as expected
so this İMac i got in March 2021 is not working as it is supposed to.
it both froze and the clicks on my mouse didn’t register when the movement did today.
is it motherboard or cpu or maybe ram or big sur 11.2.3 that is having issues?
Is dit een goede vraag?
5 opmerkingen
sounds to me like its a hard drive related issue.
door
Yeah
İt may be hard drive
door
Is the hard drive on this machine backed up?
door
@andrewsawesome i never backrd it up
door
@KAAN CAN I would recommend backing up any important data before we continue.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@KAAN CAN
Problems it could be in order
  1. Drive
  2. Big Sur
  3. motherboard
  4. And if the ram was the problem it would be having purple lines on the screen right now,
  5. i don’t think the cpu could be the problem
Was dit antwoord nuttig?
Score 1
What you didn’t mention was whether you were using a wireless mouse and keyboard or one that is using one of the USB ports.
If using wireless, you might have a wifi issue, either the wifi in the machine software is corrupt or there is a hardware issue, or the batteries are dead in the control devices.
If using wired control devices, you might try using a different set (keyboard and mouse) from a known running system, and try them on a different USB port.
Did you upgrade the system to Big Sur, or did you get the machine with Big Sur already installed?
If you shut the machine down by holding the power button down (provided you have no control of the screen to initiate a proper shutdown) and then do a restart, do you get the startup chimes, or some sort of coded beeping? If you get the chimes, the machine is happy with the ram.
If the machine starts with the chimes, does it go to a log in screen, or if you’ve selected to auto login, does it go to your desktop? Or do you get a question mark or some other odd looking icon?
1 Opmerking:
İt boots normal,it has magic mouse and keyboard(they came with the imac)not wi-fi since i can join online classes eighter
İt came with catalina but i updated it to big sur in day one,no weird icons eighter
door
Voeg je antwoord toe
KAAN CAN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 14
Altijd: 79
