Ga door naar hoofdinhoud
Draagbare Bluetooth-luidsprekers op batterijen
108 Vragen Bekijk alle
Ion Bluetooth speaker won't stay charged even after 8 hrs
Ion Bluetooth speaker from Walmart won't stay charged even after 8 hours of charging with no use , unplug for a minute and it dies. Will work while plugged in but that's it.
Is dit een goede vraag?
Score 1
3 opmerkingen
I Have A Ion Bluetooth Speaker From Costco
When I Charge My Speaker It Stays Charge
I Don't Have Too Charge For Weeks.
I Play My Speaker Everyday And Can Charge My Phone
Conga Master
door
My Bluetooth speaker will work plug in the wall but I unplug it will not work has to be plugged in all time
door
@detrickmarshall
What is the make and model number of the speaker?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Given it works when plugged in but not on the battery only, it appears as though the battery is faulty or has failed and needs to be replaced.
I cannot find a teardown video online that shows how to open the speaker, but here’s a link that may help in finding the correct replacement battery.
According to the link, if you have had the speaker for <90 days from new, then the battery is covered by the manufacturer’s warranty.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you, I just came across it myself, just before checking here. Again thank you
door
I have to replace my battery. Want to know if the Ion Bluetooth speaker charging system works with lead acid batteries & lithium.
2 opmerkingen:
Mine powers on but won’t connect to Bluetooth only radio any suggestions besides replacing the battery which I did but the company sent me the wrong size
door
you need to download the app and connect to bluetooth thru the app. THEN connect to audio via phone bluetooth
door
Voeg je antwoord toe
Chris Marques zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 82
Afgelopen 30 dagen: 314
Altijd: 8,164
