audio not switching to streaming services
Vizio tv and sound bar. everything was working until today. When I switch to streaming service, I get the picture, but the sound stays on the previous channel. Have powered off and reset, but sound will not switch to streaming services.
Is dit een goede vraag?
Have you tried checking the audio settings on your TV? It's possible that the audio output is still set to the previous channel. You can usually access the audio settings by pressing the "Menu" button on your TV remote and looking for an "Audio" or "Sound" section. From there, you should be able to change the audio output to the streaming service. If that doesn't work, it's possible that there may be an issue with your sound bar. You may want to try disconnecting and reconnecting it to see if that resolves the issue.
door AlexaDuffy
