Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
Power/Sleep and Home Button Unresponsive
I have a iPod Touch 4g which has a cracked screen. I replaced it, and still didn't put it back. I attached the two wires from the screen to the iPod, and now the Power Button and touch screen are not working. I plug in my charger, and it goes to the password screen, and I can't slide it.
How can I fix this?
EDIT: The volume button also don't work :/
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Assuming that everything worked well before, the #1 culprit for malfunctioning electronics after dis-assembly tends to be dirty or poorly seated connectors. Clean everything well with a high-content rubbing alcohol and make sure the connectors are seated fully. If that all checks out, closely inspect each of the connectors and see if a pin was damaged. Good luck and let us know what you find!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I tried this, and now the display doesn't light up anymore when I plug the charger in :(
door
It is most definitely a damaged on/off, volume flex cable. There is a post elsewhere on this site.
Voeg je antwoord toe
Cytonic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,009
