Ga door naar hoofdinhoud
Valve Steam Controller, released November 10th 2015. Model 1001.
20 Vragen Bekijk alle
How to repair/clean/replace the joystick?
Steam controller joystick feels like it has some obstructions on the upper lef hand quadrant and when playing a game, even if I hit the uppermost limits on this region the character starts to walk instead of running. If I push hard enough, the character responds and starts running. How can I fix it? Is there a way to replace the joystick if I can’t fix it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
According to the teardown, the Steam Controller is relatively easy to take apart with only a T6 screwdriver. You would need to reach Step 5 to get to the thumbstick (carefully unplug the ribbon cables on the trackpads before removing from the chassis). That should at least show if there are any physical obstructions causing the behavior you observed. Brush around the stick with a cotton swab dabbed with some isoprophyl alcohol.
Worst case scenario, the thumbstick is soldered to the motherboard, so it would need to be desoldered to replace it. I'm personally not sure which would be a suitable replacement module for Steam Controller.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jason Morales zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 117
