Ga door naar hoofdinhoud
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Vragen Bekijk alle
The monitor worked fine, then suddenly made a pop and now its dead
This is not related to the common periodic flickering and then the screen going dead until you unplug it and plug it back in. That was another Thunderbolt display that I fixed with new cables. This one made a loud POP and then went dead. There was no problem or issue prior. I’ve tried a different power cable, but that still didn’t help.
Is dit een goede vraag?
1 Opmerking
@chunnel - Time to do a bit of careful inspection of the logic board and power supply for a blown capacitor! You should be able to see a burnt component.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I think the power supply died,
[gekoppeld product ontbreekt of is uitgeschakeld: IF359-001]
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you. I had that same thought. You seem to be out of stock so I purchased it for the same price on Amazon. I'll let you know if it works.
door
Alright :) i hope it works
door
Voeg je antwoord toe
Bryan Karlan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 87
