Ga door naar hoofdinhoud
battery adhesive question - how many strips
when i replace batteries, i always use adhesive, and the same stretchy type that Apple uses.
my question is, is it necessary to use the the same amount of strips? 2 for normal sized batteries and 3 for plus size batteries?
are there any downsides to using one less (1 for normal, 2 for plus)?
i don’t want to get into a debate about costs or just because.
i want to know if there’s any reason why (or how) using less than what Apple users could be bad.
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There is probably not much of a difference on a plus sized battery since it will still have two points that are attached to the housing, but on a normal sized battery I would replace all the adhesive, as one point of contact dosen’t seem very secure.
As a good rule of thumb, put it back the way you found it.
Was dit antwoord nuttig?
1 Opmerking:
makes sense. thanks
door
Voeg je antwoord toe
B C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 24
