Ga door naar hoofdinhoud
The Xiaomi Poco X3 Pro is an entry level smartphone by Xiaomi released March 2021. It is equipped with a 6.67" IPS LCD screen, a 48 MP main camera and runs on the Qualcomm Snapdragon 860.
77 Vragen Bekijk alle
Microphone not working unless I plug in headphones
Hi, recently I’ve bought on auction xiaomi poco x3 pro, seller said he checked everything before transport and said microphone was fine and working correctly, as title says my microphone is working properly only when i plug in headphones, otherwise microphone humming and i have to scream to microphone to barely hear my voice.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like a bad solder point & that it is rerouting through headphones to get the connection. It could have happened during shipping. If u feel ambitious you can open it and find it to reflow the folder
Was dit antwoord nuttig?
Score 2
1 Opmerking:
@asdasdasd sounds good. Check solder around the plug but also the contact pads/solder points for onboard mic.
Also reseat all cables & ribbons
door
Voeg je antwoord toe
asdasdas dasdasd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 1,202
