Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Could the degraded battery be Causing this?
@danj what do you think? When i plays game on it with it plugged in (Waiting for the new battery) Some times it the screen goes black then reboots,
I think its
  1. its not getting enough power to turbo but it trys too.
  2. Or the charger is not rated for enough power.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The charger doesn’t offer enough juice to run your system hard. Basically, your systems usage wattage is exceeding what the charger can supply alone, you need the battery.
Here’s another example of this issue the top end 2016 15” & 2019 16” systems with battery couldn’t render 90 mins of Red video even with a charged battery and charger plugged in without kicking the bucket! The only way was to put the system into a freezer to keep the system chilled! That way the process job would take less time.
MacBook Pro 15 (2018) - Beware the Core i9
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
@danj Thanks so much,
I though it was the battery,
Have a Merry Christmas
door
@beanman56 - Will do and happy holidays to you as well!
door
@danj I wish i could get you at present for christmas you certainly deserve one or 1B
door
Voeg je antwoord toe
Ben Capehart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 24
