Ga door naar hoofdinhoud
The Google Pixel 2 is Google's second flagship phone, released on October 17, 2017. The phone features a 5-inch AMOLED display and comes with 64 or 128 GB storage options. It is available in three colors: Just Black, Clearly White, and Kinda Blue.
20 Vragen Bekijk alle
Why is my phone no longer vibrating?
I recently replaced the battery, screen/glass, and charging assembly on my Pixel 2. Everything seems to be fine, except for a single issue— my phone is no longer vibrating for haptic feedback, message notification, or phone calls.
Because there were no new units available, I ordered a used charging assembly for my repair. I imagine the most likely reason for the issue I’m experiencing is that a) I have a bad vibration motor on the new-to-me charging assembly, or b) I messed something up during installation, which is causing my vibration motor to malfunction.
But that said, I’m not actually sure what’s wrong, how to diagnose it, or what to do in order to fix it. Any thoughts or guidance on how to deal with this issue?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
only thing i could suggest is to double check the connections and if possible pull the motor and check with multimeter for continuity and resistance.
Was dit antwoord nuttig?
Voeg je antwoord toe
James 02143 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 132
