Ga door naar hoofdinhoud
De Xbox 360 is de tweede spelcomputer die Microsoft maakte en werd uitgebracht op 22 november 2005.
My Xbox has Heat Problems
Hi,
my xbox has a problem with overheat. When i play on this console it will after 10 minutes overheat and the console turn automatically off. When I restart come the advice that the console overheat Also is the console very loud. My question is how i can fix this problem.
Thanks for fast questions
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Archer,
The first thing I would do is clean the machine. Open the case and dig in to the internals using this guide and blast everything with compressed air. Once you are sure that everything is nice and clean, re-assemble and be sure that where-ever you place your xbox, it has sufficient ventilation (IE it's not in some small cabinet or on carpet). You may also consider some sort of external cooling fan and/or setting the xbox so it's standing with the CD drive vertical to give more cooling surface area.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks for the fast answer but the problem is still there. I Had the console cleaned. I used external Fans. Is there an other solution?
door
leave the cover off, plug in, turn on, watch the fans.. they might need replacing, or you may need to replace the thermal paste a la RROD repair before you get the RROD.
door
Voeg je antwoord toe
Archer564 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 654
