Ga door naar hoofdinhoud
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Vragen Bekijk alle
How to open the magsafe adapter brick?
Hello, i know its a hard work and it will be a lot of cosmetic damage to the brick of the magsafe, but how can i easily split the case of the magsafe, to solder the wires again?, also i'd like to do minimal cosmetic damage to the charger, thank you :)
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
These things were not built to be opened as there are really no serviceable parts. I've used a Dremel type tool with a cutting disk to get into them with minimal damage. I cut along the seams.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Dario zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 1,509
