Ga door naar hoofdinhoud
The Plantronics Voyager Legend is a wireless, Bluetooth enabled headset, which is compatible with most cellphones available on the market. Originally released in September, 2013, this device is still popular among a wide variety of users.
Do battery replacement instructions also work for Voyager 5200?
The Plantronics Voyager5200 looks almost identical but is in fact different (Rtings has side-by-side pictures). Do the battery replacement instructions for the Legend also work for the 5200? Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
basically yes they are almost identical. Just be sure you get the right battery with the right leads.
Was dit antwoord nuttig?
5 opmerkingen:
Did you actually perform a battery replacement on the headset? I am sure that they are identical from the inside, but the fastening of the case looks quite different, if you look at the pictures.
door
@jastram I did it on the new one. They are the same type of pressure snap clips so be gentle when you separate.
door
@jastram
https://www.youtube.com/watch?v=oXuHwYJv... (Legend)
https://www.youtube.com/watch?v=odVpATQO... (UC)
Hope this helps a bit more than me just saying it's very similar!
door
Those videos are useful, thanks. In fact, they show that disassembly is easier than with the Legend.
door
@jastram not a problem. if this answered your question please chose an answer but if you have issue you can still come back and ask
door
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 501
