Ga door naar hoofdinhoud
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Controller will not turn on without being plugged into something?
My Xbox Elite Series 2 controller does not function at all without being plugged into the usb-c or sitting on its charging dock that it came with. The power button works, the accessories app claims it has a full charge, the firmware is up to date, everything works great then as soon as it’s unplugged, it’s a brick. It acts as if there is 0 charge to the battery. What do I do?
Update (11/28/2021)
Sorry I should’ve specified I’m using this on PC no console. I’ve gotten a wireless adapter and it will connect wirelessly but only when attached to it’s charging dock. As soon as it’s removed the controller doesn’t turn on. It does work completely fine with a wire attached, the issue is the controller won’t turn on at all without a wire attached, or it being mounted on a charging dock.
Is dit een goede vraag?
5 opmerkingen:
I'm having the same issue with my Elite Series 2 controller it only works plugged in with the usb-c. It register full battery, but when I disconnect the cord it's dead in the water. It's been gong on since April or May. All the forums are a no go so far. HELP!!!
door
Is there any new fix for it
door
I have this issue too!
I have to plug it into power supply to switch on but mine works if you unplug it though, the home button works fine, it's gotta be summat to do with standby voltage to the home button!
Any suggestions 🤔
I'm OK with soldering and pad/trace repair but this has me stumped.
I'm gonna solder a battery to the board and check some voltages!
Anybody on IFIXIT know anything to look for???
LOVE MY IFIXIT SCREWDRIVER SET, BEST PURCHASE EVER THANKS GUYS!
door
My controller just stop working with or without being plugged in , I've had it for a yr now , what should I do?
door
Hey man. The battery inside the controller goes bad after so many charges. It’s a really easy replacement and fairly cheap to fix. It’s just some screws pull the old batter pop the new one in and let it charge. I haven’t had a problem since I replaced mine. My battery was swollen once I opened it up. I hope this helps
door
Voeg een opmerking toe
1 Antwoord
The cable could be worn out or broken. Make sure it's securely plugged in on both ends. If that's not the issue, unplug it from the Xbox One and plug it into a different USB port on the console. If the controller still won't turn on, disconnect the Play & Charge cable and try a different micro USB cable.
Was dit antwoord nuttig?
2 opmerkingen:
Any suggestions 🤔
door
Keeps disconnecting with cable plugged in. All up to date firmware tried multiple cables usb ports use on PC says the device or usb has malfunctioned used it for 3 years issue started this month. Unsure if it will be an easy fix
door
Voeg je antwoord toe
Kevin Cotter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 208
Altijd: 7,051
