Ga door naar hoofdinhoud
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Vragen Bekijk alle
SSD and RAM Upgrade
Hello,
I'm interested in upgrading the RAM of this computer. Please tell me which of the following RAMs is considered most suitable for my model.
Also i want to upgrade my HDD drove to SSD. The following is considered suitable for my model ?
Thanks a lot
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
For RAM, the first and third links you provided will work. The second link will not work because the memory is not low profile.
As for the SSD, the one you linked to should work.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Thanks a lot Andrew!! ?
What is low profile memory ? Do you have a better suggestion for RAM regarding this iMac ? Do you think that I will have a significant outcome if upgrading ram from 4GB to 16GB ? What about 8GB ?
door
@g_atticus You will see the most improvement from upgrading the SSD.
The RAM should be upgraded to at least 8GB as well. You probably won't notice a difference in performance from 16GB of RAM vs 8GB RAM unless you play video games, do video editing, or have many tabs open at a time on a web browser.
door
Hello and thanks again for your answer!!
I do not do any of the things you describe other than the many tabs on the internet which is rare. I am thinking very serious instead of 16GB to go to 8GB mainly because of the money difference. What do you think ? If I decide to upgrade to 8GB which one do you consider appropriate for my iMac ?
1. https://www.amazon.com/Corsair-CMSX8GX3M...
2. https://www.amazon.com/Crucial-2x4GB-Lap...
3. https://www.amazon.com/Crucial-PC3-12800...
4. https://www.gskill.com/product/2/161/153...
door
@g_atticus All of the options provided will work.
door
Voeg je antwoord toe
Panagiotis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 47
