Ga door naar hoofdinhoud
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
20 Vragen Bekijk alle
Bluray drive keeps spinning up with no disc every 10 minutes?
Hey if anyone can help. Bluray drive keeps spinning up with no disc every 10 minutes ?
I replaced the Drive and swapped logic boards. I think some sensor is not working correct. I am also unable to turn the console off.
What I have worked out is if there is a disc in the drive it seems to work and operate as normal.
Does anyone know how to fix it ?
Is dit een goede vraag?
1 Opmerking
Hey @tomchai you seem to be a guru, Any ideas
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Does it happen predictably every 10 minutes? If so, I guess some sensors are latched triggered and the drive is cycling to try to clear that. The sensor is ignored when the disc is loaded so it doesn’t happen with a disc inside.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Hey Tom, thanks yes it does happen predictably. On first boot up it spins up loud at full speed. Then roughly at the same intervals. I haven't timed it. Is the sensor on the daughter board ?
door
@kgm316 From what I remember, the sensor is on the roof of the drive enclosure. If you have replaced the whole mechanical part of the drive, maybe some front end circuitry on the daughterboard is having issues.
door
I had this problem. had to replace the disk sensorfrom the underside of the drive from the original to fix this problem
door
Voeg je antwoord toe
Kelly Moore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 85
