Ga door naar hoofdinhoud
A 13-inch "2-in-1" laptop with a 360-degree hinge that allows it to convert to a tablet-like form factor.
Battery compatible with my device?
Hello, I wanted to confirm that the Dell WDX0R battery listed for the Inspiron 13-5368 would be compatible with the Inspiron 13-5378? The battery is completely dead, so it can be only used on AC power and I wanted to replace it.
Dell WDX0R Battery
Thanks!
Replace a dead or malfunctioning battery for laptops using a Dell model WDX0R battery. Afbeelding
Product
Dell WDX0R Battery
$69.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Dell WDX0R Battery
according to what I can find no they are slightly different but here is the correct battery
Product
Dell WDX0R Battery
$69.99
Was dit antwoord nuttig?
Score 1
13 opmerkingen:
Hi @stressmaster ,
In the link you posted it shows that the battery, model # WDXOR, is compatible with a Dell 13-5368 and a 13-5378.
It's the same battery model number as shown in the image for the ifixit one, so it should be the same or am I missing something?
If necessary the OP can check using this link to check for compatibility using the laptop's service tag. It is also a WDXOR battery
Cheers
door
@jayeff you will notice that that model doesn't show up in the like. I believe it is a Wh thing or a screw placement.
door
@stressmaster The wh just means it will run longer, especially if this battery has a higher Wh rating then the original. The voltage has to match or be in the supported range, but you can upgrade the Wh on a laptop battery.
door
@stressmaster
It can't be a screw placement otherwise what's the point of model numbers?
If they had different model numbers, albeit only a suffix to the model number, then fair enough, that would denote that they're different in some way.
This link also shows that a WDXOR battery is compatible with both models that the OP asked about.
door
@jayeff looks like you're right and it's compatible. Maybe ifix needs to update listing
door
8 commentaren meer tonen
Voeg je antwoord toe
Auchhior zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 272
