Ga door naar hoofdinhoud
The HP Envy 7640 is an all-in-one inkjet printer with a built-in scanner and faxing capabilities. It can be connected to your devices via Internet, WiFi, or a USB cable.
Load noise while printing and print is barely visible
While my printer is printing we hear a very load noise almost as if it is struggling or grinding. Also, when a page is printed, it's not clear seems as if it doesn't print properly and the ink is almost full so should print clearly. Thank you for any help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Those are two different issues. First the low ink issue. The print heads can get clogged and there is a clean printhead function. repeat several times until you get good ink.
second one is likely a plastic gear that you will need to find and replace.
Was dit antwoord nuttig?
Voeg je antwoord toe
Krystal Torres zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 201
