Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1202 Vragen Bekijk alle
iPhone X 0% Remaining
Hello, I have an iPhone X which had a battery replacement, and was working fine until it randomly restarted and the battery percentage now shows as 0%. The battery health also shows as service, but before the restart it showed as 100%. It also randomly restarts, does anyone know what the issue may be? Thank you
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Your battery have loose connection with battery connector or battery connector have been damaged while replacing battery…..so go and have ok on it
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
If you have ruled out the battery it will most likely be an IC2 SDA or SCL problem. Check readings on battery connector data pins. Check for nudged components Q3200 and Q3201. If all looks good replace U3300.
Score 4
1 Opmerking:
Sometimes is battery and sometimes MOSFET can also cause it, because when is damaged it can result to 0%remaining. Check very well close to the battery terminal and change the MOSFET...
door
Sounds like you got a bad battery. Try another.
Voeg je antwoord toe
Colby Morris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 92
Altijd: 3,673
