Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
Panic CPU x caller - Reboot every 3 minutes - Charging Port Flex?
I am looking for ideas to help fix a problem I’m having with an iPhone X. Bear with me while I describe the history, what I’ve done so far, and what the current symptoms are.
The customer said he had originally had the screen replaced at a mall kiosk and it worked well for a couple of months but one day it would not turn on. What I actually found was the phone was turning on but the screen had failed and was not turning on. I installed a new screen and all seemed well. I gave it back to the customer in seemingly 100% working condition. A few days later he brought it back to me and said it was rebooting every few minutes.
  1. I tried forcing an update - no change, still rebooted after a few minutes.
  2. I tried a DFU restore - no change, still rebooted after a few minutes.
  3. I googled the issue and found numerous reports about issues with the charge port causing the phone to restart every 3 minutes. I checked and confirmed the phone would reboot after 3 minutes consistently. So I ordered a new charge port flex.
  4. I first tried to temporarily disconnect the original flex in the phone and temporarily connect the new bare charge port flex. Voila, the phone stayed running beyond 3 minutes.
  5. I disassembled the phone, removed the original charge port flex, reinstalled the new charge port and reassembled the phone. Initially the phone seemed to be fixed. But after several hours I noticed it starting to go back to the 3 minute reboot cycle again. Grr. Maybe I damaged it during installation I thought.
  6. I ordered another new part and repeated step 4 and 5 but with greater care. Again, with the new part installed the phone seemed to fixed. This time I set the screen to stay on and started a stop watch. The phone stayed on for over 3 hours so I left it overnight.
  7. In the morning, the phone was BACK TO RESTARTING every 3 minutes!!!
  8. For fun I disconnected the 2nd new flex that was installed in the phone and connected one of the other charge ports that I had swapped out. With only the charge port by itself connected the phone still reboots. Conclusion - the flex is getting damaged somehow just by connecting it to the phone (my theory anyway).
  9. Some posts on here suggested a DFU restore fixed this issue - in my case, it does not. Tried it. No difference.
I dug into the analytics logs and using 3U Tools see that every time it reboots it logs a “Panic CPU x caller” entry.
Here is the detailed text from one of these entries. Has anyone seen this? What can I try next? I’m hesitant to install a third charge port but do have one if need be.
Thanks in advance for your help,
Larry
{"bug_type":"210","timestamp":"2021-11-06 21:28:52.00 -0600","os_version":"iPhone OS 15.1 (19B74)","incident_id":"41C3AD2D-4165-42EE-9166-C156236A84EC"}
"build" : "iPhone OS 15.1 (19B74)",
"product" : "iPhone10,6",
"kernel" : "Darwin Kernel Version 21.1.0: Wed Oct 13 18:16:58 PDT 2021; root:xnu-8019.42.4~1\/RELEASE_ARM64_T8015",
"incident" : "41C3AD2D-4165-42EE-9166-C156236A84EC",
"crashReporterKey" : "d6ac110a82cef07ecd55c818d6c8d79130b244dc",
"date" : "2021-11-06 21:28:52.45 -0600",
"panicString" : "panic(cpu 1 caller 0xfffffff02941f0f4): userspace watchdog timeout: no successful checkins from thermalmonitord since load\nservice returned not alive with context : is_alive_func returned unhealthy : current 7bfffffffff, mask 67fffffffff, expected 67fffffffff. SD: 1 BC: 0 Missing sensor(s): mic1 \nservice: backboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins since load (168 seconds ago): 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord, no successful checkins since load (180 seconds ago)\nservice: runningboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nDebugger message: panic\nMemory ID: 0x6\nOS release type: User\nOS version: 19B74\nKernel version: Darwin Kernel Version 21.1.0: Wed Oct 13 18:16:58 PDT 2021; root:xnu-8019.42.4~1\/RELEASE_ARM64_T8015\nKernel UUID: 13E2F321-3388-3B9E-9D68-75E2081A4A02\niBoot version: iBoot-7429.42.2\nsecure boot?: YES\nPaniclog version: 13\n
Is dit een goede vraag?
Score 6
6 opmerkingen
i have the same issue but my phone does’nt restart in 3 min my phone is restarting random time some times it restart after one hour some times it restart after 20 min
what should i do
door
@MIR GamingYT Best way to get answers is to start a new question. Check for panic log entries and add them to your post if any are present. The first page or so is usually sufficient.
iPhone Kernel Panics
door
Dear,
I had the same isseu with my ipad 6 and it ended up in a bootloop then only recovery. not able to restore it.
I did something you could try as last resort if the device is compleet dead like mine.
I did it in the past with gpu,s and i put the logicboard in the over for 10 min at 180 degrees coverd the ports and charging port with thermal pads and it works fine now .
door
I have the same problem but I notice that when my phone is running something in background it won’t restart, AO I turned on background sound in my control Centre and put the volume to zero and it always stay on as it should be but anytime I forget to turn it on my I’ll always meet my phone switched itself off
door
hi try use jailbreak my phone no crash with jailbreak and without jailbreak ervery time ctashhhhhhhhhh
door
1 commentaar meer tonen
Voeg een opmerking toe
10 Antwoorden
Gekozen oplossing
“no successful checkins from thermalmonitord since load” It is either the charge port or in rare cases could be the housing causing it. You need to source a charge port from a reputable supplier. If you purchase elsewhere there is a good chance the sensors on it are faulty or non-existent.
If you are repairing phones you should have a known good housing and screen for each model. This way you can eliminate a parts issue in the least amount of time.
Was dit antwoord nuttig?
Score 6
5 opmerkingen:
Thanks. I do not have a spare housing but I'm curious, how would the housing cause the assembly to fail? 99% of my parts are purchased from Mobilesentrix.
door
@larry767 From the 8 series up I have noticed if the housing replacement is not genuine it seems to create problems sometimes in the buttons or the wireless charging. I always have a known good working housing so I can completely rule out parts. Alternatively you could remove the board and just have the screen, battery and dock connected. I would also try another charge port from a different supplier as they can get faulty batchers in.
door
Just as a confirmation of this. This panic specifically refers to missing mic1. That’s on the charge port assembly.
door
"panic(cpu 0 caller 0xfffffff028f6e140): "i2c2::_checkBusStatus SCL is stuck low; last read status 00010100 int shadow 00210100 xfer 00000000 fifo 00000000 for device audio-speaker-top"
door
Hi sorry, I think im having the same issue. Can someone help me identify what it might be? I can send in the crash report it's giving me.
door
@tempestgaming, I trimmed your panic log, as anything past the first page is useless to anyone but Apple development engineers.
That being said, in most cases the springboard error you're getting is attributed to software. Early versions of iOS release 16 seemed to be particularly prone to experiencing this issue, and the fix has usually been to do a system update to a newer version. Obviously that's not the particular problem you're having, as it appears you're on iOS 17.4.1 according to your log. If you haven't already, you might want to take a look at iFixit's Wiki page on kernel panics; it has a section on the Springboard error you're seeing
Anyway, I would suggest you check for an update and if one is available, then you should do the upgrade; there's a fair chance that may fix the issue for you. If not, The next best thing would be to put it in DFU mode and reinstall the OS. That will be the most complete update possible and will restore everything to factory settings. If you no longer see the problem, then you can start adding back your apps one at a time; there's a chance it could be one of them causing the issue, so the challenge there is in isolating which one it is.
Give this all a try then come on back and let us know what you find. If it's fixed, that may help someone else with the same problem, and if not we can try and figure out what your next step should be.
Score 2
From iPhone 8 upwards you MUST use genuine charging flex because they have temperature sensors which are not present on generic otherwise they will reboot every 3 minutes, if the original flex is not damaged you can swop the port only.
Score 1
I had the same issue . I bought My
3 months ago “12 pro max 512” One day it felt a little slow so I decided to reset the network setting however It never booted back and got stuck on apple logo for more than 5 hours.. then i decided to not wait any longer and restore it using iTunes . unfortunately after restoring it gets stuck again on the Apple logo. at this point I was pretty !#^&@@ so I factory reset it and had to suffer a significant data loss . What a f cking garbage ! Highly overrated pice of junk . Never again
Score 1
I experienced the same issue on iPhone XS Max, and iPhone X. The only solution that has helped me was to change the entire housing. Get a complete casing from a local phone engineer or used phone spare parts reseller.
Score 1
1 Opmerking:
Hi. I had this bug pop up in my log, on iPhone XR after troubleshooting an issue on my paired Apple Watch 6. My Apple Watch 6 is on, and display is blank, but is working perfectly in voice over mode. Basically, it’s working in every way, I can erase/restore/pair/unpair an Apple Watch 6 (does not meet current repair service program requirements FYI) completely blind! And the only trouble I’ve had on any devices linked to my iCloud, is on my watch. Does anyone know if that error could be related? Had Apple account lock down on me too, right after troubleshooting watch. Was forced to update my password to unlock account, right after I finished troubleshooting watch… and saw this in my log. Time stamp coincides with all strange behavior, too. Something weird is going on.
door
Did you try booting the phone with prox disconnected? I’ve seen prox sensor cause boot loop
1 Opmerking:
Yes and it made no difference. It's not a boot loop. It boots but doesn't detect "thermalmonitord" within 180 seconds and reboots.
door
Sorry for late reply but as others said about back housing…I agree with them….you can then try to unscrew all screw that connect logic board and back house you can disconnect back camera too.then turn on the phone and check.
You can ask why?
The reason is screw can short to ground and cause some issues like phone turned on but no display,phone turned on but dark camera and so
4 opmerkingen:
OK, thanks for that explanation. I ended up killing the phone taking it apart and reassembling it so now it won't turn on (draws 0 amps). I sent it away to a friend who can diagnose and repair shorts and damaged components (microsolder repair) and he's been helping me troubleshoot this for several weeks. Hopefully he has spare parts and such that can get to the bottom of this issue. I'll report back when I know more.
door
Okay if it drain 0A he must check PP_BATT_VDD and PP_VDD_MAIN(350-470 diode value) if are both okay then there must be loose connection between logic board and signal board. So my advise separate the phone and test using iSocket if no hope let me know for more assistance
door
panicString” : “panic(cpu 1 caller 0xfffffff01c6e3fac): SMC PANIC - ASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit:
door
“product”: “iPhone15,3”,
“socld”: “8120”
“socRevision” : “11”,
“incident”: “67069C14-0C79-4B29-9AB3-4796B08286EC”
“crashReporterKey” : “18ceaa6d6278e8a1c8bf5f2dcc45d2e9fca86b36”
“kernel”: “Darwin Kernel Version 24.2.0: Thu Nov 14 22:52:05 PST 2024; rootx : 12025-10-16 17:22:15.87 0200”7 8120”,
“panicString”: “panic(cpu 1 caller Oxfffffff03a1053d4): AOP PANIC - [Eiger.cpp:644] assert: <0x102c294> 0x0 - main (5) OUTBOX3 not ready - \nuser
handlers:\nEiger::probe=0 [e4 30 1] conn=0(n|nPrAS Comp = stat [0, 01, dbg [327832, 143461923, 49430753, 0, 48790226, 640523, 1, 16084, 4] In|n\n[Eiger.cpp:644] assert: <0x102c294> Ox0|nRTKit: RTKit-2758.60.101.debug - Client: iphone15aop:DEBUG:AppleSPUFirmwareBuilder-634.60.19~4304 n!UUID:
door
Had the same issue
i solved it by removing the small flexcables that came on the housing
just swap the old one over
1 Opmerking:
can you be more specific on which flexcables so i can buy the right ones?
door
Can anyone tell me where is the problem for this issue?
{"bug_type":"210","timestamp":"2024-05-11 11:45:08.00 +0800","os_version":"iPhone OS 17.4.1 (21E237)","roots_installed":0,"incident_id":"2165ACA5-A8B7-42CF-80E7-335779178F14"}
"build" : "iPhone OS 17.4.1 (21E237)",
"product" : "iPhone14,5",
"socId" : "8110",
"socRevision" : "11",
"incident" : "2165ACA5-A8B7-42CF-80E7-335779178F14",
"crashReporterKey" : "c3568e239a8fb4a0438f25de1fbcbccb95288a0d",
"kernel" : "Darwin Kernel Version 23.4.0: Fri Mar 8 23:31:19 PST 2024; root:xnu-10063.102.14~67\/RELEASE_ARM64_T8110",
"date" : "2024-05-11 11:45:08.73 +0800",
"panicString" : "panic(cpu 0 caller 0xfffffff044aca934): userspace watchdog timeout: no successful checkins from SpringBoard (2 induced crashes) in 180 seconds\nservice: backboardd, total successful checkins in 175930 seconds: 17364, last successful checkin: 0 seconds ago\nservice: SpringBoard (2 induced crashes), total successful checkins in 175910 seconds: 17344, last successful checkin: 180 seconds ago\nservice: mediaserverd, total successful checkins in 175930 seconds: 17363, last successful checkin: 0 seconds ago\nservice: audiomxd, total successful checkins in 175930 seconds: 17364, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 175930 seconds: 17364, last successful checkin: 0 seconds ago\nservice: thermalmonitord, total successful checkins in 175930 seconds: 17363, last successful checkin: 0 seconds ago\nservice: runningboardd, total successful checkins in 175930 seconds: 17364, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 175930 seconds: 17364, last successful checkin: 0 seconds ago\nservice: configd, total successful checkins in 175930 seconds: 17364, last successful checkin: 0 seconds ago\nservice: CommCenter, total successful checkins in 175930 seconds: 17363, last successful checkin: 0 seconds ago\n\nDebugger message: panic\nMemory ID: 0x1\nOS release type: User\nOS version: 21E237\nKernel version: Darwin Kernel Version 23.4.0: Fri Mar 8 23:31:19 PST 2024; root:xnu-10063.102.14~67\/RELEASE_ARM64_T8110\nFileset Kernelcache UUID: C9A613E1AD603469931D7C4F3C4D9305\nKernel UUID: 3F715130-4277-3E54-BE34-D1019A869CE2\nBoot session UUID: 2165ACA5-A8B7-42CF-80E7-335779178F14\niBoot version: iBoot-10151.102.2\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\n
i also got same problem with my xsmax
and battery is stuck at 1 percent and it keeps on rebooting every3minutes
{"bug_type":"210","timestamp":"2025-03-30 16:56:05.00 +0530","os_version":"iPhone OS 18.4 (22E239)","roots_installed":0,"incident_id":"F615B08B-43B0-4FC0-9B97-C56A90737553"}
"build" : "iPhone OS 18.4 (22E239)",
"product" : "iPhone11,6",
"socId" : "8020",
"incident" : "F615B08B-43B0-4FC0-9B97-C56A90737553",
"crashReporterKey" : "049c93f5b527a2bb8ab03e27e4088f1a8bb4df9d",
"kernel" : "Darwin Kernel Version 24.4.0: Sat Mar 15 18:26:11 PDT 2025; root:xnu-11417.102.9~20\/RELEASE_ARM64_T8020",
"date" : "2025-03-30 16:56:05.67 +0530",
"panicString" : "panic(cpu 1 caller 0xfffffff01612762c): userspace watchdog timeout: no successful checkins from thermalmonitord (2 induced crashes) \nservice returned not alive with context : is_alive_func returned unhealthy : current 7fffffffffffc, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 1 RC: 0 BS: 2, Missing sensor(s): TG0B TG1B \nservice: backboardd, total successful checkins in 198 seconds: 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 166 seconds: 17, last successful checkin: 0 seconds ago\nservice: audiomxd, total successful checkins in 198 seconds: 19, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 198 seconds: 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord (2 induced crashes), no successful checkins in 198 seconds\nservice: runningboardd, total successful checkins in 198 seconds: 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 198 seconds: 19, last successful checkin: 0 seconds ago\nservice: configd, total successful checkins in 198 seconds: 19, last successful checkin: 0 seconds ago\nservice: CommCenter, total successful checkins in 198 seconds: 18, last successful checkin: 0 seconds ago\n\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 22E239\nKernel version: Darwin Kernel Version 24.4.0: Sat Mar 15 18:26:11 PDT 2025; root:xnu-11417.102.9~20\/RELEASE_ARM64_T8020\nFileset Kernelcache UUID: AD9F8CBDF22046F00018DE3EF758127E\nKernel UUID: D56F0DC2-C0FA-3CF6-AF51-25010F38F5C7\nBoot session UUID: F615B08B-43B0-4FC0-9B97-C56A90737553\niBoot version: iBoot-11881.100.993\niBoot Stage 2 version: \nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\n
2 opmerkingen:
Again, I trimmed your panic log down to just the first page, as the only information useful to us is on that part.
You're missing the TG0B and TG1B sensors, both of which are inside the battery. I just replaced the battery on an iPhone X that was showing the exact same symptoms, and a new battery fixed the problem. Doing so will resolve your issue as well.
door
replaced the battery but still the same
door
Voeg je antwoord toe
Larry Jorgenson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 183
Afgelopen 30 dagen: 763
Altijd: 83,837
