One Fan Spinning Full Speed After Battery Replacement
I just replaced the battery in the machine, verified all the connects a couple of times. One fan spins at full speed 100% of the time and I can’t figure out why. I tried all the standard resets too…any ideas?
Is dit een goede vraag?
5 opmerkingen
Hmmm. Only one fan? Which fan, just out of curiosity? I would try 2 things. See if it spits out an error when you run diagnostics (press and hold D when you power on from off). I might also download something like TG Pro, there's a 14 day free trial, and see if you're getting any weird readings from sensors.
door Alisha C
@flannelist - Good diagnostics step!
door Dan
Did you try reseting the SMC and or NVRAM?
door Ben Capehart
So, here is where I'm at. I did all the resets, like SMC and NVRAM. I downloaded TG Pro like @flannelist mentioned. That all came back clean, no issues. The left fan though is running at 7000 RPM and the right fan is at 2000 RPM.
I started the machine up in a diagnostic mode and there it did say that something was up with the left fan. So not sure if this is an issue with the fan itself or the connection to the MLB/
door Greg Dietrich
i would try the fan MacBook Pro 15" Retina (Late 2016-2019) Left Fan
if not then this MacBook Pro 15" Retina (Mid 2018) 2.9 GHz Logic Board, Radeon Pro 560X, with Paired Touch ID Sensor OR MacBook Pro 15" Retina (Mid 2018) 2.6 GHz Logic Board, Radeon Pro 560X, with Paired Touch ID Sensor. OR MacBook Pro 15" Retina (Mid 2018) 2.2 GHz Logic Board, Radeon Pro 555X, with Paired Touch ID Sensor
Or its the ram that could cause that to happen
can you send a video of it starting up and the sound or a link to youtube or something
The problem with my 2009 macbook was the fan it wasn't going fast enough.
door Ben Capehart
