Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Can I switch it off with only the home button working?
I replaced the battery but had some issues getting the old battery out - it exploded dramatically and I ran out of the room. I was eventually able to get it out and replace after cleaning up the mess it had made. Amazingly the phone came back on but whilst removing the old battery I broke the cable running from the volume controls across the top. The phone is on but the power button doesn’t work to shut it down and the screen is not responsive. How can I switch it off so I can open it again? Or do I have to wait for the battery to drain? I’ll replace the broken cable first and check all cables are connected then I see what else might need replacing.
Is dit een goede vraag?
1 Opmerking
Open the screen and disconnect the battery. It will be perfectly safe.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If your phone is running iOS 11 or later, you can turn it off by going to Settings>General>Shut Down (at the bottom).
Unfortunately, there is no way to turn off your iPhone without a responsive touch screen or working power or volume buttons.
Was dit antwoord nuttig?
Score 1
You can use Siri to turn on Voice Control, and from there you can say “show grid” and navigate to Settings>General>Shut Down. It will be a hassle, but it’s doable. If you don’t feel like going through the trouble of that, while I can’t recommend it, opening a phone that is still turned on to disconnect the battery is a viable option if all else fails. I’ve have to do it before, and everything worked out. Just make sure you are in an ESD safe environment and that you use a plastic spudger to disconnect the battery. Also, keep any metal tools away from the logic board itself as you may inadvertently bridge a connection and fry your phone.
Voeg je antwoord toe
hannahlatham@hotmail.com zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 19
