Ga door naar hoofdinhoud
Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
71 Vragen Bekijk alle
Are the batteries glued in?
Are the new 2021 14” MacBook Pro’s batteries still glued into the case like with previous models? Or have they improved the battery replacement story, alongside the other “pro” improvements they've made such as re-introducing the HDMI port and SD card slot?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The battery on this model has pull tabs that make it easier to take off the adhesive.
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
It's still a bit early, I've not seen any clear teardowns on the battery yet.
I'm sure the iFixit team will give us a good detailed teardown soon!
door
İt does have pull tabs
door
Voeg je antwoord toe
Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 3,117
