Ga door naar hoofdinhoud
Nothing happens when you press power button?
I can't get anything to happen when I press the power button
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
tested 110 vac coming into power supply but nothing coming out of out put side.
Thanks David
Was dit antwoord nuttig?
2 opmerkingen:
Here's the power supply
iMac G5/Intel Power Supply
door
Het nuttigste antwoord
I've got to ask some questions to be able to help. Do you get any lights at all? If so, do they flash? If they flash, how many times? Any sounds?
Thanks
Score 1
2 opmerkingen:
Open the back by removing the three screws in the bottom of the frame. Plug it back in. See if any of the LED lights in the middle of the board are on. Just to your left of the lights should be two small gray button. Using a pencil eraser tip hit each one and set if the machine turns on. One is the reset & one the start up and let me know if you get any results.
door
mayer, once the iMac is open he could check for bulged or leaking capacitors don't you think ?
door
There are no lights at nothing happens.
I think it is power supply but not sure.
Thanks David
3 opmerkingen:
There are three main failures with this machine. First was the power supply, look for burn spot. The second was bulging and corroded capacitors, look at the 25 cans. Third is a older separation on the GPU chip that gives video problems. If your capacitors show symptoms and your power supply is gone the it is not worth trying to fix this machine. Let me know and if needed I'll go into how to transfer your data to a new machine.
door
noticed heat under where power supply .
I inspected motherboard and no problems found.
also hard drive on this machine was wiped clean and tested fine,ram tested fine,dvd and fans tested good!
I have another power supply ordered so I think i will give it a try.
door
Please look at the bottom of your iMac stand and send the information. We may not have your correct machine listed.
door
Voeg je antwoord toe
David Payton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,861
